2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-04T23:26:56+00:00
    Hello wylht
    Do a two button shut down as described Here.  Manually check for and install any additional updates available.  Restart Surface and check again.
    Best regards
    2015-11-04T23:51:18+00:00
    I have this exact same issue, along with a slow/unresponsive mouse if I'm using an external monitor on my SP4 through my trusty SP3 Docking station. I've tried restoring the graphics and display drivers to the old version using the files here: https://www.microsoft.com/en-us/download/details.aspx?id=49498  I'll let you know how it goes.
    2015-11-05T03:38:53+00:00
    I tried this. Not much use.
    Now, I have more than 1/2 chance when wake up, Surface can display but report "display driver is broken and now recovered"
    2015-11-05T14:01:17+00:00
    I'm now seeing that if I leave my Surface Pro 4 on at my desk and it puts itself to sleep, then I can not get it to wake back up.  It's the i5/256/8GB model with a Type Cover on it and nothing else.  When I try to wake it, the keyboard will light up and thats it.  The only way to then bring it back from the dead is to hold down the Power Button and Volume Up button.   At that point I am brought into some device setting menu and then if I exit I am then rebooted back into Windows.  The latest update from 11/2/15 was applied that night.
    Anyone else seeing this problem?
