2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-08T01:49:20+00:00
    This is what I'm going with. I'm losing around 2 or 3 percent battery per sleep hour with Wi-Fi on using the USB hub workaround. I could probably get it a little better if I fiddled with it a bit but I'm not going to bother. If I need better I'll just hibernate it. As it is now using the workaround I'm getting 12-13 hours (Surface Book) of heavy use and intermittent connected sleep before needing the plug, and that's plenty for me. If it's not going into as deep a sleep as it's supposed to with the workaround, I'm ok with that. What I'm not ok with is unreliability and I don't want to exchange it because I don't know if the problems will reemerge at some point again on the new machine, or worse, inherit a whole new set of problems. Not to mention the arduous task of setting up a new machine and any loss of productivity that it might entail. Right now, everything is working on my SB and I like it a lot when it works.
    2016-05-08T05:12:09+00:00
    Don't accept this, once your year warranty is out, it will be harder to replace this device even if it is a silent recall.
    Anyway, I took the 3 hour round trip and went to the Microsoft Store. Told them everything I did, showed them my box and lot # 1541, and they didn't even make me prove it wouldn't sleep. I think they could tell I knew what I was talking about and my device was in mint condition. Got a NEW replacement, lot # 1613, and just got everything installed on it outside of my development tools. I had a lot less than that on the lot 1541 unit after a reinstall because I didn't trust that it was going to be fixed.
    And so far, it slept perfectly several times so far, where before it would have failed without a doubt. I'll see if it holds up...also my USB on the new unit was set to Manage Power like it should.
    I was also getting a lot of stuttering and locking at times using Google Chrome, I haven't noticed that yet with this new unit.
    I will keep everyone up to date, ask any questions if you like. Again lot# 1613
    2016-05-08T10:02:58+00:00
    My SP4 wakes up fine but I use the power button to put it to sleep and wake it up. It works using the keyboard sometimes but not always so I just use the power button. If I try the keyboard I have to press the key a few times.
    2016-05-08T11:03:43+00:00
    I have had my brand new Surface Pro 4 for about a month and am overall very happy with it; apart from one massive problem! All my power settings are set to 'sleep' my surface, however whenever I leave my surface for more than half an hour it wont wake from sleep and I have to force a restart! I have tried changing the timings for sleep / lock screen times, changed the power button settings and updated drivers. Does anyone have any further suggestions? It is seriously disrupting my work as every time I come back to my desk I have to force a restart and re-open everything I was working on! Thanks!
