2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-07T17:46:23+00:00
    what is your USB root hub power management defaulted to on this new device. Sad, this is exactly why Microsoft is losing to Apple especially and Android
    This?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=56415c30-cc44-4e71-b575-ffcffd6a0235)
    2016-05-07T18:07:34+00:00
    I have a Surface Book, but I've found a solution that works for me, and I think it should work for the SP4 as well. Just the other day I remembered that I had the same problem with my old Windows RT tablet, and was able to fix it. I charged it up, found out what I did and applied it to my Surface Book, and it appears to have solved the not waking problem. Everything seems to be working better actually. Here's what I did.
    1) Right click on the start button and select device manager.
    2) Go to the bottom and expand "Universal Serial Bus controllers"
    1. Right click on "USB Root Hub (xHCI)" and select properties.
    2. Click the "Power Management" tab and uncheck the box for "Allow the computer to turn off this device to save power"
    3. Click ok, and that should do it. Like I said it permanently fixed my RT tablet, and I haven't have a failure to wake on my Surface Book since I did it a few days ago. I was going to wait a few more days to make sure it was a permanent fix but I saw this topic and figured I'd post it now. I also posted this in the SB forum.
    I don't know why that fixes it, or why this continues to be a problem since Windows RT. Maybe someone could finally release a patch that fixes this?
    Hope this helps!
    This sounds like a neat find for those still having issues with sleep.  Just to add to the mystery, my SP4 has been doing fine in regards to sleep, and the box REMAINS CHECKED.
    2016-05-07T19:33:39+00:00
    Hello - Just sent my own Surface 4 back for replacement given the same issue with Sleep.  it was a 1542 version.  on top of everything it had a weird talent at failing to install updates :)
    does anyone know a way to identify if the surface that got sent back is new or refurbished? (infact the person i spoke to on the support desk (chat) told me they dont have refurbished models to offer and that they are all new)
    any ideas to understand lot besides seeing it on box?
    2016-05-07T21:15:26+00:00
    I exchanged for a new SP4 at the local Microsoft store 9 days ago.  So far no sleep issues!  Did not have to turn off USB root hub.  Seems to me this is a hardware issue...
    I believe the ones that Microsoft sends through technical support are refurbished / remanufactured ones.  I was told I can only get new ones from the store.  I was sent a refurb that had the same problem and the Microsoft technician directed me to the store for a new one.
