2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-07T06:16:35+00:00
    Seems to work! 10 attempts and wakes every time.
    2016-05-07T11:18:21+00:00
    Great! Hopefully some more of the 1134 people who have this problem are able to apply this fix!
    2016-05-07T11:22:12+00:00
    It works but there is side effect: battery drain when sleeping (USB hub is always powered on).
    I've noticed 2-3% / hour which is significant (3 * 24h = 72% / day!).
    2016-05-07T11:39:05+00:00
    I've always had 2-3% an hour or even more battery drain when sleeping so I haven't noticed a change.
