2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-05T16:41:51+00:00
    Are you in Canada and did you get an advanced exchange or a standard exchange?  They told me only standard exchange applies for Canada.  If standard how long did it take you to get the standard?
    2016-05-05T17:49:49+00:00
    I'm in Florida. It was an advance replacement. I thought they were committing to shipping it within 3 days, never mind the shipping time. Turned out it was at my door from Canada in less than two days.
    2016-05-05T20:31:48+00:00
    Sorry to hear people doing an advance exchange and getting a refurb to see it fail the same way - maybe the "refurb" is my old machine cleaned up and put into a new box?
    • Peter
    2016-05-05T20:54:55+00:00
    I'm wondering if we have this all wrong. I don't seem to recall if anyone has tested the sleep function on another OS, perhaps Linux ?
    The reason I ask is because as good as Win10 is for improved speed and security over previous version of Windows, It's still bug ridden from a user experience point of view which is very evident in the feedback app. One just has to look at the daft issues such as deleting files from Windows Explorer requires a user to press F5 or the refresh button more often than not (a problem that never existed in older OS's) and the numerous dodgy sync issues that are reported etc. etc.
    So that being said .... i'm wondering if pre redstone is the problem. I'd love to be able to test this but the SP4 is currently my daily driver ... so if anyone has already tested another OS ... it would be good to know.
    Cheers
