2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-05T01:46:34+00:00
    I don't get it
    2016-05-05T02:08:09+00:00
    I just checked (10:07 PM EDT, 4May16) and no new updates since April 19.
    2016-05-05T02:23:36+00:00
    Well it seems to me the majority if not all of the guys reporting that they had them replaced recently have not reported problems. I got my replacement today, advance replacement by the way, so I am not left without a working unit and it seems to work fine thus far.
    But if you rather spend time here complaining about the issue and hoping for a fix rather than taking proactive steps to resolve it by all means have at it.
    I am of the mind that it is almost always better to do something than to do nothing.
    2016-05-05T03:02:49+00:00
    I'm in the Insider Program on the Release Preview Ring so maybe that has something to do with it? Running build 10586.240
    The updates all seem to be Camera focused anyway...
