2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-05T00:31:39+00:00
    Another Boatload of Drivers coming down from Windows Update folks. Prepare to be teased and then disappointed yet again!!!
    Will post a status on if this works right off the bat, but be forewarned, take what I say with a grain of salt until I see it working a week from now.![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=5891d1a1-9b9c-43b8-9a73-2911e14e63de)
    2016-05-05T00:41:43+00:00
    Ahhh. Driver day is always like old fashioned European Christmas. Waiting breathlessly to see if Santa will come, or if I'll get visited by the Krampus instead. Based off of my experience with driver day so far, I won't be leaving out milk and cookies...
    2016-05-05T01:03:21+00:00
    Don't bother with today's driver updates for testing sleep, same old story, doesn't work! Back to hibernation and hopefully the Microsoft Store on Saturday to return this thing before I throw it across the effin room.
    2016-05-05T01:12:58+00:00
    Maybe there should be a release with instructions on how to update the driver(s) when you cannot get the device to wake up!
