2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-03T16:12:48+00:00
    I can report after a little bit over 36 hours of success after those STEPs, the problem has resurfaced and I've had to revert back to hibernation.
    Good while it lasted but non the wiser on if its SW/HW. I'm tempted to think HW but surely if it was, then why would I have 1.5 days without incident (with heavy testing of both user and system initiated and different durations) and then all of a sudden, come back. Clearly the DISM did something to stable a situation that affected me on over 90% of sleeps, so I'm still of the mind that it's SW related.
    2016-05-03T19:59:17+00:00
    You sound confused, like the rest of us, and probably the people looking into this issue at Microsoft.
    All I know is...the device doesn't work as advertised, and no one can figure out why. Not a good sign
    2016-05-03T20:05:46+00:00
    More importantly, the device manufacturer isn't standing by the device or working with customers to try to find a stopgap solution that can hold until they can figure things out. Even good companies can make bad products, but a good company will do what it takes to make their customers whole.
    2016-05-03T20:54:25+00:00
    But the device manufacturer (or the company whose logo appears on the device) _IS_ standing by the device - they have a silent recall in place (I know - it's only my pet theory, but many signs are pointing there). I don't believe it's a coincidence that when I showed up at the Microsoft store complaining about the sleep issue, they didn't put up much of a fight and gave me a replacement - and also complied when I demanded a certain lot number or higher.
    I don't think Microsoft has definitively identified the root cause, but they know that empirically a population of their devices has this issue. It also doesn't seem to be a black and white issue - it's more of a "spectrum" issue (where some devices have less probability of it occurring and some devices always crashes in sleep, etc.).
    • Peter
