2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-01T16:52:26+00:00
    Thanks for sharing your experience.  This "fix" didn't work for me back when Microsoft Support suggested it soon after the February firmware made the waking issue much, much worse on my SP4.  But I thought I'd give it another go, just in case things are different with the latest updates.
    I followed your list of instructions exactly after doing a fresh reset from the recovery image and running Update until nothing changed.  SFC /SCANNOW came back with no errors.
    It didn't help - I experienced the usual black screen/lit keyboard issue upon waking within a few hours.
    Is your machine still waking correctly every time?
    2016-05-01T17:12:48+00:00
    Sometimes you should using Ctrl+Alt+Delete just after trying wake up while its display seems to off.
    2016-05-01T17:50:34+00:00
    Thanks, but that has never worked on my machine.  Nor has Ctrl-Windows-Shift-B or Alt-P.
    If Ctrl-Alt-Del works to wake up your SP4 from a black screen after sleep, could you tell us your hardware configuration? (I have i5 8GB 256Gb)
    2016-05-01T20:32:28+00:00
    Lot 1612 SP4/I5/8GB/256GB working perfectly after one week of use no SLEEP issues thank goodness.  My other SP4 was lot 1547 and I had to reset it nonstop! All updates installed except Microsoft driver update for Surface Management Engine, INTEL driver update for Intel(R) 100 Series Chipset Family PMC - 9D21, and Microsoft driver update for Surface System Aggregator Firmware.  In update history they say "Failed to install"
