2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-01T08:32:22+00:00
    This was happening to me too, after despairing at the length of replies to this post and some of the very technical solutions.
    I went into Power Settings (just search power settings from Cortana)  and set the Screen to never power down and just rely on the Surface itself to sleep after 5 minutes, it starts so quickly anyway from Sleep that there can't be much difference from just the Screen going to sleep.
    Anyway mine has been behaving itself for the last 24 hours.  Hope this helps someone else as its a pretty none tech solution.
    2016-05-01T13:26:35+00:00
    This is not good to hear you have the exact same problems with a brand new SP4!!!?
    I went to the below and followed the instructions to download on a USB Stick. Just do NOT follow the whole process to repair and reinstall (unless you want to). You just want the repair image to fix the issue.
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage
    2016-05-01T13:42:43+00:00
    I have fixed the opencl.dll issue as well and have a clean sfc /scannow
    BUT I still have NoWake/BlackScreen problems, so this isn't the fix for NoWake/BlackScreen.
    2016-05-01T15:19:15+00:00
    That's one of the reasons I'm leaving my SP4 as virgin as possible after the Reset.
    FWIW, mine is still crashing and burning:  I walked over to it this morning (it was asleep or hibernating, I presume, as all settings are default), undocked it, and it refused to turn on with the usual black screen of death.  (Keyboard lit, etc. once I attached the Type Cover.)  Had to hold down power button for longer than normal, it seemed, to force shutdown.
    Makes me wonder if it might have been OK if I had awakened it before undocking...
    Hey Microsoft!  This is still broken!  Fix it! If that means you have to provide us all SP3's and then swap for newer, reliable machines (SP5?) when available, then so be it.  There is no way we should have to put up with computers that so blatantly deviate from what you advertise as portable, reliable, productive, instantly usable, and with long battery life (not to mention the kind of implied expectation that it won't catch fire in your briefcase...)
