Another longish post, with some new observations...
OK, after the last round of updates, my SP4 started to get really unstable again, not only with increased Intel Droppings all over the screen, but also with intermittent failure (again, on my second SP4) of Activity Center and Start Menu/Cortana. (Basically,
the "Modern/UWA/UWP" components of explorer.exe stop working, but you can still (sometimes, until it gets really bad) right-click on the Start Button to get to the old Win7 admin interfaces/tools. Right-clicking Start was the only way I could even shut the
machine down yesterday morning.)
I thought about heading over to the Microsoft Store for yet another hardware swap, but decided to try a Reset first. (I told it to preserve my files.)
Still a major PITA: It takes at least half a day by the time you go through all the updates/reboot cycles and reinstall the desktop apps, so it's as much trouble as a hardware swap, but ~2 hours quicker (so I could actually get some work done yesterday).
On top of that, I decided to stick with the devil I know, since my current SP4 is devoid of other common hardware complaints such as light bleed (which I've never experienced) and noisy whistling/whooshy fans (which my first SP4 *definitely* suffered from...)
A few interesting observations:
- sfc /scannow still says things are corrupted even after a completely clean Reset and applying all updates (in several cycles, with reboots). I simply don't trust that P.O.S. anymore - I think it's lying to us and keeping us chasing our tails around an
issue that is either not an issue at all, or for which there's no real effective fix in any case. DISM if you want, I don't think it helps at all, and I'm not running an executable from some unknown schmuck on Reddit to create a .wim for the DISM dodge. (BTW,
I should get a substantial refund from MS just for trying to paw through all the **** in sfc's ridiculous cbs.log file. It's one of the most useless and obfuscatory log reports I've ever encountered, even putting Cisco to shame...)
- Interestingly, far fewer updates were installed after the Reset than I expected. Here's the complete list, as reported now:
3. This would tend to indicate that the image being restored by a Reset isn't completely a local one, but rather one that includes updated components from Microsoft's servers as well.
4. Note that the firmware and other updates are not reapplied (this makes some sense, really - they're still there, but you now have no way at all to know that for the firmware updates proper, and even the drivers can only be checked by painfully pawing through
the driver versions in Device Manager. Whatever Windows Update is using to really check the status and versions of things seems to be unavailable to us for monitoring...
5. With the exception of continued (but less frequent?) Intel Droppings on the screen (especially, but not entirely in Firefox - other programs are more likely to have blank areas or faulty draw, especially in init/resize), things are generally better. I
haven't tried undocked sleep yet.
6. Start/Cortana/Activity Center functionality seems to be restored to normal. (This was not the case with the corruption on my previous SP4, where a Reset was not effective.)
7. This could have something to do with the settings, too - most system settings were changed to default by the Reset process. For instance, it lost all memory of the display configuration (I have an external 4K monitor attached through the SP3 Dock), and
Hello is now turned off. As handy as Hello is (and other than the new pen, it's really the only reason anyone would prefer an SP4 to an SP3), I'm leaving it off, since some have reported that helping, and I'm really into Surface pain avoidance now.
8. Power Settings were also reset to default. I'm leaving them completely alone for now to see what happens. The really good news is that the machine woke up normally this morning - when I got this replacement SP4 clean and updated on the fateful 2/17, I
had to tell it not to sleep when plugged in to avoid a forced poweroff/reboot every time I stepped away for more than a few minutes.
9. Caveat: I haven't restored all my applications yet - just Office, Firefox, Chrome, Amazon Reader, and Adobe Reader so far. Win 8/10 seem to be especially allergic to some Corel software, so I'll run for a few days until I need CorelDraw again to see if
there's any before/after difference there...
10. I have an SDXC card in my Surface all the time. A post earlier today indicated that could be affecting sleep - it's a factor I hadn't considered. With only the remainder of a 256 GB drive, I really need the storage of the card (and it sure makes restoring
things easier, too), but may pull it if I have continued power/sleep problems.
Anecdotally, then, for the first time ever, it appears that my SP4 actually is somewhat more stable after a Reset. I've tried a Reset in the past (before 2/17) with no results other than a wasted day - this time it seems to have actually helped. (But keep
in mind that this is only because the Surfce/Win10 combo sucks so badly that it corrupted itself and I had to do this ridiculous and painful Reset in the first place - It's completely unacceptable to expect Surface customers to do this just because Microsoft
can't build a system that works! In addition, it's fiddly - doing this correctly is well beyond the capability of most Windows/Surface users.)
(BTW, a quick tally shows that I've spent easily upwards of 80-85 hours directly futzing with my Surface devices in the past year because Microsoft cannot get their act together. That doesn't count the time spent in endless poweroff/reboot/relaunch-all-apps
cycles, which adds another couple of days and tons more frustration...)
