2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-29T12:39:47+00:00
    I fixed my opencl.dll issue using the below which I had ON A NEWLY INSTALLED image I just reinstalled on my day one SP4. It didn't help fix the Black Screen, no wake issue, but it did fix the error and now sfc /scannow finds no errors. Interesting that I had the error on a brand in image I installed yesterday...what a mess.
    http://serverfault.com/questions/741487/how-to-fix-corrupted-opencl-dll-in-windows-10-if-sfc-and-dism-are-failing
    1. I used the Surface Recovery Image that I used to reinstall the OS from scratch the day before
    2. Dism /Online /Cleanup-Image /RestoreHealth /Source:esd:D:\sources\install.esd\1\Windows\WinSxS\wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\
    3. It gave an error at 100%, but seemed fix the opencl.dll issue as step 4 had no errors
    4. sfc /scannow
    And btw, I have almost nothing installed on this reinstall...just Google Chrome 32-bit. Yet 95% of the time, NoWakey
    2016-04-29T12:41:15+00:00
    Agreed! Great device, extremely frustrating though...not sure it's been worth the bleeding edge. I'd rather have a SP3 with the SP4 keyboard honestly.
    2016-04-29T13:08:49+00:00
    As I mentioned, I did the DISM trick, just for a clean sfc response.
    Before and after I did the fix, this Surface Pro3 has no sleep and wake up problems.
    That’s why I think, it’s not related.
    But I agree, that it is at least 'interesting' that almost every clean Surface tabled gives sfc scan errors,
    the more that we need the DISM trick to fix it.
    2016-04-29T15:25:02+00:00
    How did you get the /Source image?  I tried running DSIM hoping it would use Windows update, but it gives an error that there is no source.  Did you use the Media Creation tool to create an ISO?
    I'm having the exact same problems as you are with my brand new SP4
