2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-28T12:18:31+00:00
    THE SLEEP ISSUE IS SOFTWARE RELATED, NOT HARDWARE.
    I installed the INSIDER BUILD 14332 and the sleep issue just disapeared. No problem in the last days.
    Before that I had all updates made ok, I had the last Firmware correctly installed, did the sfc /scannow and /restore method, reinstalled, recovered, all You can think of, but had still 60% of the time black screen on wakeup.
    Since the update to build 14322 no black screen, no stupid screen wake, all is how it should be.
    so again:
    2016-04-29T03:21:11+00:00
    No Offense, but I'm not buying it!
    2016-04-29T03:33:19+00:00
    None taken.  Try it!
  4. Deleted
