2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-28T05:58:48+00:00
    To fix the corruption that sfc couldn't fix, follow these steps -
    https://www.reddit.com/r/Surface/comments/46unyx/how\_to\_fix\_dism\_error\_0x800f081f\_and\_sfc\_failed/
    I had to download the very large image to fix this. Again, no effect on sleep for any of the machines I tried.
    • Peter
    2016-04-28T09:42:18+00:00
    Cannot get away from black screen. All updated, and just now having starting problems. 2 key restart gives the Surface logo for 3-5 seconds,  then a blue & white info screen,(all I can see is something about  firmware level & what appears to be a selection menu on the left.  Frustrating after all previous problems with docking station.
    2016-04-28T10:03:56+00:00
    The DISM command I run (after sfc /scannow) is below:
    Dism /Online /Cleanup-Image /RestoreHealth /Source:wim:C:\windows\install.wim:1 /limitaccess
    The bolded part is the path to the install.wim file extracted from the appropriate Windows 10 system ISO which you can download from the techbench:
    https://www.microsoft.com/en-us/software-download/techbench
    The wim file is in the ISO 'sources' directory.
    2016-04-28T10:46:36+00:00
    Even after the April firmware update, I am still experiencing the sleep of death on my i7 Surface Book. I have read numerous posts on Reddit that people are still experiencing it.
    I have tried:
    • The sfc /scannow and /restore method (even a Surface tech remote controlled my SB)
    • Reinstalled Windows 10
    • Recovered from USB
    Nothing has worked. I have a feeling it is a hardware issue and not a firmware/OS issue. I think we need to let Microsoft know that despite their best efforts (which I know they are trying their best) that there is an issue somewhere whether it be in production, the new Intel CPUs, the firmware or OS.
