2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-28T03:06:24+00:00
    Ok so Sunday night I reset my surface. Downloaded all windows updates. They all installed except for intel corporation driver update for Intel HD Graphics 520.Windows said it would try updating again in the future. I did not set up windows hello, I signed in with a pin.I also installed the watchdog timer driver & driver update for intel 100 series chipset thermal subsystem from the surface diagnostic tool. I left all sleep settings to there default setting.Miraculously My sleep issues have disappeared. I have put this to sleep for half  an hour,1 hour ,2hours, 5 hours & 8 to 10 hours. All with good results. Thinking that this is all tied in with windows hello. Have not set up windows hello for fear that this thing will not wake up. I also have not gotten the update for intel hd graphics 520. I will keep testing thru out the week & keep you posted.
    2016-04-28T04:59:32+00:00
    What I'm saying is the Watchdog timer IS NOT installed at all on our systems. When we run the Diagnostic Tool it adds it, it doesn't update an older version of the Watchdog timer.
    2016-04-28T05:05:58+00:00
    Well I just did a complete recovery from a downloaded recovery image, reinstalled windows from scratch, not keeping files, not using the image on the machine.
    Nothing installed, just syncing OneDrive and changed the screen to go off in 2 minutes, with the default sleep on battery at 5. First system initiated sleep...BLACK SCREEN...tried all the tricks to no avail. Just wasted hours of my time, hopefully I won't have to waste more as I'm ready to dump this machine.
    2016-04-28T05:41:06+00:00
    Oh yes, i did check the sleep for longer than 120 minutes - it doesnt hibernate at all when plugged in. I left my machine charging overnight so yes, I had it sleeping for good eight hours or more - it still came back (my older machine always crashed in that scenario).
    • Peter
