2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-27T23:10:39+00:00
    On my new lot 1604 computer, I have installed everything that I had on my old (returned) computer. The sleep has not given me any problems so far - rock solid for 4 days since I got the new machine.
    So the thing that people swore (on Reddit) that made a difference - sfc /scannow and a fix involving DISM - doesn't matter on the new hardware at all. I've used the machine without the fix originally for a couple of days without any sleep issues. Then on a whim, I decided to run it and it had corrupt files that sfc couldn't repair. So I used DISM to repair it and rerun sfc - as for sleep behavior, there was zero difference. For me, I'm believing more and more that the hardware is a big part of the issue.
    On my lot 1604, the sleep is exactly as I had expected - no (or very little) battery drain when sleeping, wake up with keyboard or power button, when it reaches hibernate timer, it goes into hibernate. This thing works as advertised.
    I'm running Chrome, Edge, skype and steam in the background.
    I remember that on the old computer (lot 1550), I tried -
    1. sfc, dism repair, sfc
    2. 2/17 updates, no exclamation on the device manager screen
    3. 4/19 updates, no exclamation on the device manager screen
    4. Complete hardware reset
    5. Intel beta display drivers
    6. Surface toolkit, and updating the watchdog timer
    7. shift-control-win-B
    8. win-P
    9. power button - single tap, double tap, etc.
    10. detach keyboard - reattach keyboard
    11. click on the pen button
    12. plug in a USB mouse
    13. plug in a display port monitor
    NONE of them worked. The new machine fixed the sleep problem.
    As for people saying on this forum that the new machine isn't necessarily a fix - either they are Microsoft shill or there really is some variation even with the new hardware. I say keep returning the machine until you get one that works - you can be first name basis with the Microsoft Store guys. :-)
    As for how extensive my testing is -
    1. setting - Hibernate after 120 minutes
    2. setting - display off after 5 minutes
    3. setting - sleep after 5 minutes
    4. I try waking up the computer 5 minutes after sleep
    5. I try waking up the computer 30 minutes after sleep
    6. I try waking up the computer 60 minutes after sleep
    7. I try waking up the computer 3 hours after sleep (needs to power up since it's hibernated)
    So I think I'm giving the sleep function a thorough workout.
    • Peter
    I would suggest you are not giving it a thorough workout, as many folks would want to know will it wake after SLEEPING for 120 minutes, avoiding hibernate.  Hibernate was a known fix for many of us for a while.  Why are you using hibernate at all?
    2016-04-28T00:15:24+00:00
    Watchdog timer isn't a fix, it's an addition. It's really only needed for Enterprise management.
    2016-04-28T00:24:36+00:00
    Peter,
    Could you share the DISM repair command you are using? I couldn't find one that worked, and I'm about to do a complete recovery image as a last ditch effort before I drive and hour and a half to exchange to PITA 6 month old machine for what better be a new one that works.
    2016-04-28T00:43:10+00:00
    Actually, considering what a watchdog timer actually does (basically, reset stuff when a program goes off in the weeds - see my earlier post on this), it's probably vital that it be fixed to ensure stability.  It's unlikely to be needed for enterprise management unless it keeps wake-on-LAN or the like from working.
    As I've said before, though, this problem shows all the signs of *multiple* timers, state machines, and drivers in various (dynamic!) software, hardware, and firmware components fighting like strange bulldogs in a bag, which is why MS and Intel are reduced to playing a "whack-a-mole" game trying to fix this.
    The fundamental problem is really crappy architecture in the first place (Surface devices aren't the only PCs suffering, just the worst), and I strongly suspect that a fair part of the problematic architecture is cast in silicon (hardware), making software/firmware workarounds even more difficult.  (Hence Microsoft's claim that this is a "very hard computer science problem, especially with new hardware."  This is why I suggested moving to ONE state machine to rule them all, put wherever it needs to be - probably in firmware (what passes for a BIOS these days), if there's enough code space there (and there may not be, which could make this approach anywhere from way harder to impossible...))
