2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-27T13:21:08+00:00
    All, there were some driver updates released on 4/24 to the Intel graphics device and some other things. Check to make sure those drivers were installed and the driver has a date of March 2016. I don't expect that this will fix everyone's problems with sleep and waking, but for those where the root cause is a graphics driver issue, it might. The notes for the driver specifically say it solves issues with the driver not waking from sleep, and fixes monitor issues with the docking station.
    2016-04-27T14:39:18+00:00
    Dyndragon, are you able to post a link to that Intel graphics driver?  I just did a quick search and couldn't find one with a version number later than 20.19.15.4409.
    Thanks.
    2016-04-27T14:51:24+00:00
    I forgot to mention the other annoyance with SP4 waking - about 30% of the time when it does wake OK, it fails to reconnect with my bluetooth mouse, so I have to turn bluetooth off then back on again to reconnect.
    2016-04-27T15:02:43+00:00
    In the last week I've done the following:
    • Run the Surface Diagnostic toolkit and updated the few drivers that it identified
    • Run the latest 4/19 update
    • Ensured that my power profile is set to go from sleep -> hibernate after 60 minutes both on battery and plugged in.
    So far I've had no issues in the week doing this.
    I did have an issue the first night, not having set my power plan as above.  I flipped the lid closed at the end of the workday, undocked and went home, at which time the Surface was very hot in my bag.  I strongly suspected that, by suspending it while plugged in and then unplugging it, it didn't go into hibernate and therefore overheated.  Since changing the suspend->hibernate for both AC and battery modes, I have had no issues since.
    Regards,
    -Doug
