2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-26T22:44:06+00:00
    Thanks Susan, it is about time someone removed the 'answered' tag on this thread!  I doubt that Microsoft cares as they don't seem to want to acknowledge this problem and the fact it is a continued problem for all of us.
    2016-04-26T22:51:35+00:00
    Thanks Susan, it is about time someone removed the 'answered' tag on this thread!  I doubt that Microsoft cares - they don't seem to want to acknowledge this major continued problem and I wish they would at least have someone explain why the surface engineers cannot come up with a solution.
    Is it because the surface engineers cannot reproduce the problem?  Is it because they have no idea what component is causing the issue?  Is it because no one is working on the issue?  If you know anyone on the surface team maybe you can nudge or poke them?  Thank you for your volunteer efforts and time by the way and I do realize your influence is limited but do you know if anyone on the surface team monitors or follows the community forum for the Surface Pro 4?  Any insight would be great.
    2016-04-26T23:42:30+00:00
    Are you using Chrome to browse?  I have noticed that Chrome tends to introduce little freezes to the system, including the start button, taskbar ect.  In fact sometimes I have to exit chrome to get the system moving again.  I've found notifications not popping up as well.  I only just installed chrome to try out the new .50 version and immediately noticed all the unresponsive behavior.
    I don't get these problems with firefox.
    I use Chrome occasionally, but Firefox is my primary browser as well - and it will be until I find something that's at least as good as Firefox and TabMix Plus at flawlessly handling 100-200 tabs. (Don't even try to tell me I shouldn't have that many tabs...)
    BTW, the whole system doesn't freeze, just some part that's needed to run "Modern/UWA/UWP" apps.  Apparently, parts of the OS are now Modern apps: the Start menu, Cortana, and Activity Center, at least...
    2016-04-26T23:44:43+00:00
    I am going to unmark the proposed answer as not being an answer as I'm still seeing pain here in this thread and I don't think the issue has been solved.  My apologies to Josh_F but I'd rather be honest here.
    Thank You, Thank You, Thank You!!  I just wish someone at Microsoft had been this honest months ago...
