I discovered this community thread after encountering the SP-4 version of the "screen of death." I only use my Surface Pro 4 during travel, so it has not had everyday use since purchase in October 2015. The problem occurred for the first time after a trip
last week. The only thing I had done differently was put it in airplane mode while on a flight. I did a Power OFF shutdown on the plane and all seemed well until I opened it at home--black-grey screen and lit keyboard. There was no response until I followed
the instructions in this thread about holding the power and volume buttons. It came back okay, but I have been concerned about the machine after reading all of the problems with early versions.
Today, I have had Surface on for observation only for about 4 hours now with no problems. I opened some Office documents to see if they were available upon wake-up. It goes to sleep every 5 minutes but awakens on command.
I have one of the early machines (LOT 1541). Here is the info on processor and settings:
Windows 10 Pro
LOT 1541
Processor
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Installed RAM
4.00 GB
System type
64-bit operating system, x64-based processor
Pen and touch
Pen and Windows touch support with 10 touch points
Running with:
Battery saver OFF
Screen—turn off after 5 minutes (battery) 10 minutes (plugged)
Sleep—sleep after 5 minutes (battery) 10 minutes (plugged)
Stay connected to Wi-Fi while asleep
Tablet mode OFF
SOFTWARE INSTALLED: Office, Google Chrome, Dropbox, Acrobat Reader
