2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-21T19:41:52+00:00
    You know I got tired of waiting for a fix and of course the 4/19 fix didn't really fix anything at least for me. I recommend that everyone just call Microsoft and send them back to them for an exchange. I mean enough is enough, it seems that people are having good results with the new ones and replacements so why keep fooling with this nonsense.
    Send them back for replacement before the warranty expires on you.
    PS they will send you a replacement and then you can send yours back within 15 days.
    2016-04-21T20:59:34+00:00
    Very good advice; however, one additional recommendation; if you have access to a Microsoft retail store handle the exchange thru them.  They are far more motivated and helpful then the MS helpdesk and if you make a good case with them you can end up with a new SP4 not a refurb.  After all, your sp4 has been faulty since the day you received it, which in my view justifies a new unit not a refurb.
    2016-04-21T21:06:34+00:00
    Agreed, I would have preferred going to the store. I just moved to Dallas Fort Worth and while they once had two stores in Dallas they are both now permanently closed......
    I wonder why :)
    2016-04-21T21:57:57+00:00
    Lot 1724 i7 16GB 256SDD - still experiencing issue after updates, all updates installed without issue yesterday.  Was hopeful but no fix here.
