2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-17T01:31:22+00:00
    "Microsoft Store, how may I help?"
    "I need to exchange a defective unit."
    "We don't have any of that model in stock."
    "Can you order one and hold it for me?"
    "We can't place orders. You will have to call back."
    OK, I know the kiosk stores are a little gimped, but come on. Employee I talked to was very nice, but they need to have more power to get things done Microsoft!
    *Immediately after.*
    "Microsoft chat, how may I help?"
    "I need to exchange a defective unit, but I DO NOT WANT A RUFURB!"
    *needless continuation of conversation proceeds*
    "Ok, we will do an advanced exchange for a MS Ceritified replacement."
    "So a refurb?"
    "Yes, but it is guaranteed to work."
    *end chat*
    *Drives speedily to the nearest Apple Store.*
    Good job Microsoft! Your ridiculous nonsense has run me off, LOL.
    2016-04-17T01:33:52+00:00
    My SP4 I5/8GB/128GB hardware lot 1547 is going back to best buy tomorrow, going to see if they can find me a newer batch.
    2016-04-17T02:14:42+00:00
    I would test it first.  If its good why return it?  Its pretty quick to find out which ones are defective.  Put your stock machine in sleep for about 2 hours.  A defective one will most likely crash.  I'm not sure that lot numbers are an acid test.  Just more likely to see good units in the later batches.
    2016-04-17T02:17:17+00:00
    Chief Scientist, I repeated all your steps, exactly, but it made no different to my sleep issue.
    I'm glad it worked for you though.  It means it's not a hardware issue - for you, at least.
