Im not sure about whites (it looks fine overall), but I did look for light bleed yes - and cannot notice one yet. Also no discernible flicker at low brightness.
Battery still draining faster than a sink after... well a full bottle of Drano.
After a mere 45 minutes or so, walked out with a brand new Surface Pro 4. Super-helpful store clerk assured me device is from very recent batch - from this year.
Does the new screen have better whites and no sign of light bleed like the other person's exchange? Might tell us all this is a problem with a defective screen.
Also pathetic it took 45 minutes and MS hasn't told stores to just exchange them already.
Hi, I'm glad you've finally got a working unit. Regarding the display, I work with digital photography and so I'm a little sensitive to the whites and resulting color accuracy of displays. For my replacement the screen was definitely of a different order
than the last.
Regarding your battery life, what kinds of programs to you tend to run daily? When I received my replacement the battery was drained completely, however it seems fine now. As an example, I use firefox (because I like to browse use the page navigator bar
as opposed to drawing pictures with my finger), and it reports 12-13 hours remaining at 94% battery. Now I'm assuming that in reality this is a little overblown, but still thats pretty good. If I use edge as a browser, I get less. Other more intensive
programs can drain the device much faster, but I'm satisfied with that.
I'd like to report to everyone on this forum, that I've still had no sleep crashes with my device since receiving the replacement. I also tried replacing the drivers manually on my last device as suggested here and it certainly didn't work. As far as I'm
concerned the fact that Microsoft is now delivering high quality units which are clearly much more reliable than the old batch is good evidence of a hardware defect. It is completely wrong of them to hide this information from the consumers and try to coerce
people into being satisfied with defective units by promising arcane, future updates and procedures that are always 'about to be released'. The original devices didn't work that well to begin with, and the Feb 17 update most certainly broke them.
Every single one of those defective units needs to go back to microsoft. I think this thread should become a center of information about this problem. If you have a device that won't wake up from sleep after the feb. 17 update, do whatever you can to return
it. If you're thinking of placing a bulk order for your company, verify that every unit you receive does not exhibit black screen sleep with all current updates applied. Send everything back that exhibits this defect. Don't waste your time looking for a
fix because there clearly is none. If Microsoft gets a reaction like this they will certainly think twice about this behavior in the future.
Well the original moderator of this forum, Josh, seems unable or unwilling to reply. Would anyone else from Microsoft care to respond to anything I've said here?
