2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-29T18:04:29+00:00
    Start at 4:44 https://www.youtube.com/watch?v=621Ur6e7JTw
    This is what you need to be doing.
    2015-11-30T00:19:23+00:00
    Thank you! That works! I am now on the beta driver and everything seems to be perfect.
    Micorosoft/Intel should have really bundled this driver for the last Nov. I hope it's only days away from Microsoft certifying this beta version. Unable to wakeup from Sleep is too much a critical bug.
    2015-11-30T00:24:00+00:00
    On the release note page for Driver Version: 15.40.12.64.4326 & 15.40.12.4326:
    It does mention it has fixed this issue:
    • System may hang on resume from S3 Windows 10 64-bit
    However, the known issues list is still rather long and Microsoft/Intel has better fix it or hide it from end users.
    2015-11-30T00:33:46+00:00
    By the way, after installing the beta drivers I had more problems with the wake screen malfunction. It appears the beta drivers helped the "display driver failed and has recovered" issue. I reverted back to the old drivers as the wake screen issue was quite significant for me with the beta drivers.
    This is such a mess.
