2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-13T20:31:48+00:00
    And one more thing Id like to add before we get into some serious microsoft bashing on this thread.  I had an ipad some years ago that I had to return SIX times to apple because they kept handing me defective units.  Apple's just as bad with these manufacturing issues, the only difference is that they're selling many more units and must admit error and issue a recall if there is a large manufacturing fault.  I suspect in this case microsoft is trying to handle the issue quietly as the Surface business is still small.  If you have a good unit, this device is superior to the ipad pro(s).  Just in case anyone's wondering...  I'm not a microsoft fan by the way but a long time mac user...
    2016-04-13T20:33:51+00:00
    I wonder if there are others that have a surface pro 4 with lot numbers in the 1600s that have perfect working units. I have a surface pro 4 from lot 1541 and i get the sleep of death issue even after reinstalling windows 10 three times.
    2016-04-13T20:36:01+00:00
    My lot number is 1550.
    Just got off of chat and if the .msi package they had me install doesn't work, then it sounds like they will sent me a new unit instead of a refurb. No pretending they never heard of this problem thankfully.
    2016-04-13T20:48:23+00:00
    Was really hoping this wouldn't be the case but guessed it was the most likely problem. Whats worse is we dont have stores in the UK so this means another case of shipping it to Germany which took 1 month to get a replacement. Curse them at Microsoft for staying quiet on this.
    Yeah, that is really, really irritating...  I would encourage Microsoft to come clean about this and issue a recall for the early units.  This would go a long way to building trust and developing a customer base for the surface.
