Hello everyone, I just wanted to add my experience as it may help.
Like a lot of people here I had the #nowake sleep crash issue on my surface 4. My machine also displayed a noticeable screen flicker when set at low brightness. It had been working up until the Feb 17 update at which point it started failing. I set my
machine to hibernate and followed this thread hoping for some news from Microsoft on a possible fix. I also tried everything to fix it including completely wiping the device and restoring with a factory build several times, not installing various third party
drivers, ect. Nothing worked, my device regularly crashed during sleep. I concluded therefore that this is a hardware problem.
A few days ago I took my machine to the local microsoft store and told them about all this. The manager I spoke to recognized the issue and confirmed my hibernate work around. He then told me that according to company policy I needed to demonstrate the
problem and they needed to install a fresh build. I told them to go ahead and guaranteed that it would crash, I was also prepared to wait at the store until that happened. While I was waiting I asked a few questions to an attendant about whether they receive
many crashing machines, whether they've seen this problem, ect. He seemed intentionally vague and I got the distinct sense that they knew all about it but were instructed not to talk.
After some waiting, the manager came back and looked at my box. A wave of recognition came into his face as he saw the lot number. He asked me if I'd bought from this store, and I affirmed. He went away and came back with a new one without waiting to
test my device, and told me that this would resolve the issue. I asked him if this was one of the later lot numbers, and he looked up and nodded.
So I went home and tested the new device. It was very clear to me that this Surface was quite different from the last. The display had a warmer white point and seemed sharper. It seemed like a display from a different manufacturer than the last. Also
this device performed perfectly, with no backlight bleeding, no screen flicker on low brightness, and absolutely no sleep crashing.
So, what I think is happening here is that there was a manufacturing fault or change, probably with the displays, early on in the production and they have most likely fixed it. If you have this issue, go to a local store and get a new one. I think they
know about it but for whatever reason Microsoft doesn't want the bad press. My new machine is flawless and exactly the experience I expect for my money. For those who are waiting with flawed devices, I don't believe there's going to be a firmware fix.
