2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-29T15:24:03+00:00
    Could you help a novice with the process or steps to follow to successfully install the beta video drivers? I have a SP4. Thanks, much, for any help provided.
    2015-11-29T17:13:10+00:00
    Yeah, it's quite simple. First, you must download the drivers from the website. After you have the drivers these are the steps.
    Extract the ZIP file (don't download the EXE version) to a folder where you know where you are.
    Right click the windows menu and click Device Manager
    Expand Display Adapters
    Right click Intel HD Graphics 520
    Update
    Click "browse my computer for driver software"
    Click "let me pick from a list of device drivers on my computer"
    Click Have disk
    Click browse
    Locate the folder, and use the files there and select the driver you'd like to use.
    It'll take a little to update the driver, and then the screen will turn off and on a time or two. My person devices needed a restart so the touch screen would work correctly again, or the pen. Both devices had different reactions to the driver changes, but a reboot always fixed the issue.
    Hopefully this helped.
    2015-11-29T17:35:53+00:00
    Thanks, Kent. Very helpful. I am getting an error message that says the "device driver is not compatible with my device". I downloaded the following:
    File name: win64_154012.zip
    Version: Beta 15.40.12.4326 (Latest)
    Date: 11/20/2015
    Language: English
    Operating Systems: Windows 7, 64-bit*, Windows 8.1, 64-bit*, Windows® 10, 64-bit
    I have a SP4, i5, 128GB, 4GB RAM
    2015-11-29T17:54:38+00:00
    https://downloadcenter.intel.com/downloads/eula/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?httpDown=https%3A%2F%2Fdownloadmirror.intel.com%2F25541%2Feng%2Fwin64\_154012.zip
    That's the link I would use. I'm sure it's the same, just making sure.
    Can you give me a screenshot of what you're seeing? and possibly the last 2 steps from where you browse to the correct folder and INF.
    Let's see if we can get this fixed!
