2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-02T18:10:22+00:00
    Yes, one of the main reasons I chose SP4 over the Surface Book in my purchasing decision, was that the surface has so many iterations going back over the years, that I hoped these launch issues would not be as prevalent.  for a fourth gen product, the first week has not been as excellent as hoped for many users.
    When I experienced my "black screen of death" issue out of the box, I called the phone support tech who assisted me with downloading and reinstalling a fresh Windows 10 "from the cloud" (no USB) and then immediately updated to the new firmware.  It's only been a couple days but so far so good.
    2015-11-02T18:18:46+00:00
    I was able to get the Surface Pro 4 working again, although I am not sure exactly WHY it is working. I haven't had any problems since, and I am quite happy with it. Unfortunately, since I don't really how I fixed it, I am not sure how to fix it if it happens again.
    2015-11-04T20:49:37+00:00
    I am happy to see that Microsoft is releasing fixes quickly. But new problems arises after install this update.
    Screen can't wake up from sleep!
    After I close the type cover and make system sleep, there is a high chance that screen won't wake up when I open it again.
    I can see the red light for face recognition, I can hear the system's sound, I know the system is running, but the screen is black out. Without display, there is no way to know what is going around. I have to push the power button for 10s to power off.
    That's ridiculous, what use of a tablet if it cannot wake up from sleep?
    2015-11-04T21:35:41+00:00
    Yep I'm having this problem too now.
