2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-11T02:06:39+00:00
    This did not fix it.  As has been said elsewhere, FIX THIS microsoft.  You just CAN'T leave this sort of disruptive problem unaddressed in your overpriced machines.  How many people who can't consistently TURN ON their computer are going to buy another?  Or recommend it to others.  I wouldn't, and I'm otherwise quite pleased with the performance.
    2016-04-11T03:32:35+00:00
    my SF pro 4 has the same problem, if sleeping in long time, SF pro 4 can not wake up. With full updating from MS, only keeping power button to shutdown and restart.
    How long MS give a best firmware to fix this problem. It's really bad using all day
    2016-04-11T11:33:34+00:00
    I have exactly the same problem with 14 Surface Pro 4's.  Tilting the screen between landscape and portrait using the auto rotate feature /Gyro  consistently brings them all back to life.  Incidentally I also have the same problem with Dell XPS13's but no tilt feature in these, then Windows key and P  4 times then leave for 15 seconds seems to force the display bus to rescan and the screens come to life.
    I think it is an Intel Display Driver issue as both the sp4 and xps13 use the same driver.  I am going to try loading on the Iris 540 beta drivers from the Intel site to see if these fix the problem (version ending 4404)
    Glenn
    2016-04-11T11:49:53+00:00
    Glenn
    Hi Glenn,
    I would urge caution on this. I've been able to use Intel Drivers on older Surface models without problem but this one specifically blocks it unless you do it manually via the inf file via device manager to force it. I've known of a few instances where forcing this driver causes erroneous behavior with the touch input and causing phantom touches .... just a friendly heads up.
