2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-09T05:03:33+00:00
    Can someone check their last installed updates and post the most recent ones here?  I got this replacement unit (which hasn't had any wake issues in a week). I just  noticed that I'm unable to install any insider builds, and now that I'm looking,  I haven't had ANY updates installed since the day I received it.  So maybe it's an update that's causing the issue.
    2016-04-09T06:10:58+00:00
    It's probably because it already came with the updates already applied by Microsoft with their latest in house image.
    2016-04-09T06:23:10+00:00
    It came with build 10240, now has build 10586.164, and updated a few things on the 29th(the day I received the replacement sp4), but nothing since then. Seems odd that NOTHING has been installed in 10 days, but that's why I was asking what other people have installed![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ba3dd9c9-de45-46ac-8a54-29cb22b5f99c)
    2016-04-09T13:23:14+00:00
    Can you go into some more detail on your steps to do this? Did you download the files from Microsoft and throw them on a flash drive before the wipe? I may attempt to try this. Thanks.
    I downloaded the SP4 recovery image from MS and extracted to a USB flash drive - I didn't pay that much attention to the option to wipe the drive, but make sure you disable bitlocker, reset TPM and remove any BIOS password you may have set before starting.
    After that, boot from the USB flash drive and do your thing. It turned out I didn't need the .msi driver file as the necessary updates were downloading as soon as I logged in the first time after re-imaging, but if you plan to do this without a network connection, I would grab it just in case.
    Use this link to download the recovery image for the SP4 - you have to register your SP4 first:
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/downloadablerecoveryimage
    This is the driver download link (I chose the .msi option):
    https://www.microsoft.com/en-us/download/details.aspx?id=49498
    Directions to reset or restore Surface:
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/restore-or-reset-surface?os=windows-10
    Hope that helps.
    Wolf
