2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-08T01:23:58+00:00
    What a crock!
    OK MS if this requires manual updates, where are they, and why haven't they been posted in this thread?
    2016-04-08T01:46:22+00:00
    I don't know if it is the following KB they are talking about.  But for me, this KB does NOT solve the issue.
    https://support.microsoft.com/en-us/kb/3145770
    2016-04-08T02:01:12+00:00
    Good luck. My 1 star review has been rejected by the moderator. This is going to be my last Surface Pro, I was disappointed with the first one. I thought the #4 would be the good one. Well, luckily company paid.
    I'm wondering if EVERYONE here started asking Panos Panay if his team is doing anything about the problem, would be a better tactic? Just barrage him till he answers.
    Panos Panoy may not work for Microsoft. I am not sure how MS hired him on the first place.
    2016-04-08T02:56:18+00:00
    Starting to wish I'd waited for that new copper-colored HP Spectre. Bet it has the basics working.
    A simple "we hear you and are working on it" would go a long way. The lack of that makes things 10 times worse than they need to be.
