2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-07T17:14:46+00:00
    My Surface runs perfect since I bought it in january and I loved it. But now, since 2 weeks I have these annoying problem that it didn't wake up from sleep. I changed nothing on the system, the problem just came up without any reason. I hope they fix this soon or I will return the machine.
    2016-04-07T19:12:30+00:00
    So I called Microsoft support and got on with a tech and the answer for checking on that software update isn't as helpful as it should be since I was told the update for this issue is not through automatic updates but it is an issue that needs a manual update.
    2016-04-07T19:58:57+00:00
    Control+Alt+Delete
    2016-04-07T23:38:08+00:00
    This resets everything and you will lose your items if not saved before. This is unacceptable for such an expensive tablet.
