2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-28T11:46:10+00:00
    Hi, Thanks for your help. Unfortunately it didn't help - the surface didn't show any reaction. I needed a hardreset. 😭
    2015-11-28T19:40:28+00:00
    The updates are current to today.
    This has been going on since day 1 (about a month ago).
    Booting back up from a shut down is not a problem.
    No error messages.
    No accessories attached.
    I haven't been able to correlate it to how the screen was left on closing but I would say that 90% of the time it is chrome that is open, full screen.
    I appreciate your consideration on this.
    I am so disappointed with the time it takes to get going upon opening up the keyboard and having to fuss with getting it in action once the screen does light up.
    2015-11-29T07:45:01+00:00
    I noticed if I disable (via Power Options) the close type cover which put the unit into sleep mode and just press the power button to sleep I was able consistently wake the unit up. I also observed on the top left hand corner as I close the type cover, I saw the screen corner display 'AutoRotate' This is strange...
    All along I'm been using the type cover to close it so the unit goes to sleep but it couldn't wake up at times. This is the second unit I got it replaced a few days ago. This is not good. I hope Microsoft do something about it.
    2015-11-29T07:57:24+00:00
    This is a horrible problem..
    I've taken to tearing the keyboard cover off before turning my SP4 on.
    I'm not recommending this device to anybody until this gets fixed...
