2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-05T00:20:22+00:00
    Having just this morning changed my power settings to only hibernate, I can say it still happens when using hibernate instead of sleep. Just had it happening after I tried to wake my SP4 after a hibernate.
    "The computer has rebooted from a bugcheck. The bugcheck was: 0x0000014f (0x0000000000000000, 0x0000000000000100, 0x0000000000000000, 0x000000004f4d524d). "
    Okay, this is my take.  There was a problem, and it was fixed in February.  It is not clear why the fix was not for EVERY machine, and it's odd that if there are random quality control issues, why would it cause this one symptom....not waking up, along with heating up.  But, it seems most machines are working reasonably well now.  And hibernate seems to help most others.
    SO, if your SP4 doesn't even wake from hibernate, take it to the store and get a new one.  And don't leave the store until you test it in front of them.  And it would help the others who still can't wake, to hear how this goes.
    2016-04-05T07:13:16+00:00
    The perpetual growth of this thread would seem to indicate otherwise.  I don't feel like hibernate should even be considered a solution, either.  We may as well be using a laptop that costs half as much, if we're going to start disabling features that make the Surface worth owning in the first place.   What's next?  Full shut down, in lieu of turning off the screen?
    The average Surface 4 owner probably spent >$1000 for a device that can't do what a $49 Kindle can do... simply wake back up when you hit the power button.  It's just not acceptable, any way you look at it.
    I cannot think of any other device I've used that fails as miserably at such a basic feature.  I had to reset mine at least five times today, which is almost every time I attempted to use it.
    2016-04-05T10:44:39+00:00
    Exactly.
    2016-04-05T11:19:50+00:00
    Still not working!
    I checked, and there's no exclamation marks! I also check with windows update, and says there's no newest update.
    I can't believe the lack of compatibility of the Surface Pro 4 and Windows 10. Please release a fix ASAP for the coming update. This issue has greatly effect my productivity.
    Thank you.
