2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-04T13:10:26+00:00
    I have waited a few months after the release of Surface Pro 4 to upgrade from the 2 exactly to make sure all this issues would not be a problem for me. Sadly after all this time and complaints I have the exact same problem, of not being able to get my computer back after sleeping mode... and consequently lose informations I was working on.
    The Surface Pro 4 is a wonderful piece of machinery, but with this issues taking so long to be resolved it's losing it's image as a reliable computer....
    I hope this gets resolved fast!
    2016-04-04T13:33:06+00:00
    Sadly, this is where we are left: we must be "hip" to arcane technical switches and controls just to be able to use a $1,300 apology of a "hybrid".  And Microsoft wonders why they're STILL a laughing stock.
    2016-04-04T15:51:20+00:00
    I've got the same 'randomly won't wake from sleep issue'.  Bought my i5 128 a couple of weeks ago and have had the issue from the start.  Firmware is up to date.  Drivers are up to date.  Did the whole dism cleanup-image routine.  I haven't enrolled the computer in the Insider Program.
    I love this computer, but the wake from sleep issue is starting to wear me thin.
    • anyone running Insider builds on their surface?  How stable has it been?  I'm running it on my other pc's but I'd like to have the sleep issue resolved before diving in with my surface.
    2016-04-04T15:57:37+00:00
    Insider builds from the start.
    DO NOT PUT IT ON SURFACE.
    It's an unholy mess.
