2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-04-03T07:34:46+00:00
    same issue here.only had it for 1 month.it refuses to wake from sleep.I have to hold power button down for 35 seconds then press and release for it to reboot.the only solution for now is hibernate.not good for a $1300 dollar product!
    2016-04-03T09:27:55+00:00
    SP4 i7 / 8GB / 256GB Fully Updated
    Ditto. My observation... Chances of waking up my SP4 successfully from Sleep is about 50%.
    2016-04-03T11:40:10+00:00
    Yes I have this as well. Since the 2/17 update I get it every single time the machine goes to sleep. I haven't tried the graphics driver reboot, maybe that works as an interim solution.
    My equally big problem is, shut down does not shut the damn thing down. If I go to the windows menu and choose shut down, 95% of the time the thing shuts down, then after its off comes right back on without me touching a thing. I've had it cycle this 3-4 times before finally actually shutting down.
    Anyone else get this or have a solution? I wouldn't mind avoiding sleep, but I can't even turn the thing off!!!!
    2016-04-03T22:46:33+00:00
    So I've (just like everyone else here) been dealing with this ridiculous sleep issue. One thing that I found kind of helpful (at least for the time being) is to set the button and the type cover it "hibernate" instead of "sleep". Yes, it does take a little bit longer to start up again, but it is at least waking up and hibernate technically saves a little more battery that sleep does. Setting it to hibernate has been doing absolute wonders for me especially when it comes to not losing my work, so hopefully it can do the same for you all too.
