2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-27T02:40:20+00:00
    Anyone else still encounter the same issue to wake up from sleep like I do although having the latest windows update? This is so annoying when someone just leave the desk and come back later having to force shutdown everytime. Even worse when you have works thats not save....... 😩
    2016-03-27T15:34:54+00:00
    Even with the update installed it does not wake from sleep.
    I would be happy help submit any additional logs/ diagnostics information if the engineering team would like some field data.
    Bought this for the wife last week, and this is not making a good impression 5/6 months? after launch bugs like this still exist.  Sadly it's not looking like timely fixes are being made either since this thread dates back to October just scrolling down.  I'll spare the competition comparison because I'm sure it's heard ad nauseam, and quite frankly I prefer windows and want it to succeed.
    In the mean time I have switched all the power options to hibernate instead of sleep.  Obviously a much slower experience... we will see if it is any more reliable, but not responding at all twice in the 3 days she has had it is unacceptable for someone with no troubleshooting skills.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8832e02c-2e73-43e7-924b-5e78b6150825)
    2016-03-27T22:19:11+00:00
    Hi Josh,
    I bought my surface pro 4 about a week ago. did all the necessary updates including the 2/17/2016 but still have problems with it waking up from sleep, whether it be putting it to sleep by pressing the power button or by it going to sleep automatically after a certain time.
    As you mentioned above I checked the device manager and it seems the update has been properly installed.
    What could be the problem?
    2016-03-27T22:31:05+00:00
    Hi Josh,
    I think it would really help if folks described their problem as:
    1. Always having the problem (docked, undocked with keyboard plugged or unplugged, tablet)
    2. Only having the problem as a tablet
    3. Problem undocked with out without keyboard
    4. Only problem when docked
    There may be different issues, and we are lumping them all together. This doesn't help us or MSFT.
