2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-22T21:26:02+00:00
    My sp4 i7 512 works right and never fails to wake from sleep as do 4 other sp4s (i5s) I have setup for clients.  I do have the issue of excessive battery usage during sleep but I find it a minimal issue since I have configured my sp4 to hibernate after 30 minutes which it does even from sleep.  I do have fast startup disabled as I prefer a fully refreshed OS when I power up.  Nothing special about my installs and updates other then installing the latest betas.  I create system restore points once a week and always before installing new drivers and software.  I get 6 to 7 hours on the battery at 40% brightness with battery saver enabled and light usage(browsing, emails, ustream, etc).  Observation: if you use the keyboard a lot keep the keyboard backlight at it's lowest setting, it will give you noticeably more battery time and put a bluetooth shortcut on your desktop so you can quickly disable it when not using.
    My point is that there are good sp4s out there.  This forum is like a doctors office.  Everyone here is sick. If u only see sick people you might tend to believe everyone is sick.  On the other hand Microsoft's bedside manner has been less then acceptable.
    2016-03-22T21:32:41+00:00
    I'd like to voice the issue I'm having with my SP4 i5 256 model- My device takes 10-15-20 seconds to turn on after waking it from sleep. So what I do is close the keyboard. Opening the keyboard does nothing, ironically. I have a SP2 as well, and this is not an issue with it. This is only happening on my SP4. I have to mash on the keys multiple times to get it to wake up, and also pressing the power button also causes it to wake up with 10-20 second delay as well... :( Any thoughts?
    2016-03-22T21:39:00+00:00
    With all my respect, but you wouldn't see everyone complaining if they are not suffering from such issue. Cause the problem will start to get high on your nerves.
    2016-03-22T21:41:02+00:00
    Perhaps your experience is a bit non-representative because you have you computer going to hibernate relatively quickly. I wonder if you were to not have it hibernate if you wold see the issue. Also, the excessive battery drain is still not acceptable.
    #SurfacePro4 #nowake
