2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-21T03:52:19+00:00
    Thank you for posting that. I'll watch it and see if it resolves things. Pesky problem!
    2016-03-21T20:51:52+00:00
    This didn't work for me when mine wedged again this morning...
    2016-03-21T23:38:58+00:00
    I am currently having this same issue. I am intent on finding an answer. My first question to anyone who sees this is: Do you have Hyper-V enabled? I read that this is what is causing the screen to stay black? This may be an older blog post but maybe this could be the true problem?
    http://digitalmediaphile.com/index.php/2014/06/24/surface-pro-3-connected-standby-is-disabled-when-hyper-v-is-active/
    2016-03-22T00:25:31+00:00
    I don't have the Hyper-V enabled and have the problem.
    Don't think is that...
