2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-13T08:57:42+00:00
    I have checked the above and both seem to be fine
    However I still have the issue.
    This is my second SP4 and I have returned the first one as it has a phantom activation on its screen
    And Its ridiculous for me to repeat again and again -exchange and getting a newer one
    Why cant it just work?
    2016-03-13T14:29:57+00:00
    My first post on this topic even though I've had this problem since I bought my Surface Pro 4 when they first came out.  I think now the best approach for us users to take is to make as much noise about this as possible, get the word out to the buying public about how common this problem is.
    This problem seems to happen just as frequently now as it did before the February updates.  I don't think the updates affected it at all.
    I have been advised by a Microsoft tech to do a Windows refresh, but I see that although it keeps my data intact it wipes all my user-installed programs.  That's too much of a PITA to attempt it, especially when it seems unlikely to help.
    I was going to try exchanging my Surface Pro 4 for a new unit, but from the comments above it looks like "they all do it" and a new unit won't help either.
    It's a great machine when it's working, but ... I wish I had bought something else.  Having to do a hard reboot once or twice a day is just not acceptable.
    2016-03-13T15:59:18+00:00
    I have mine set to sleep never.  Now I am getting the Hello red light on after I leave the SP4 sitting past the screen blank time.  Very strange and I have to shutdown to get it off.
    What a strange bunch of problems.
    And what is with Microsoft being so silent on it.  I did see one note after the last update saying they were working on a problem that "some" users were having with waking.  or some thing that led me to believe they are working on it.
    Is there some kind of financial liability with just getting on this blog and saying they are working on it?
  4. Deleted
