2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-25T15:33:46+00:00
    My unit came up in password mode but I clicked on the sign in options and it switched to pin mode which then worked.
    2015-11-25T15:50:00+00:00
    This issue happens randomly. if the display driver crash (you will likely hear a sound) after when you press the button to wake up SP4 out from sleep, the screen will goes blank. Then you have to do the annoying reset. To prevent this from happening I set to hibernate instead of sleep for both power button and type cover when it is closed.
    2015-11-25T16:11:42+00:00
    Actually - after reading MS's description of the latest update, I don't see anything related to the wakeup screen problem. See below:
    https://support.microsoft.com/en-us/kb/3121244
    Recently we learned of an issue that could have impacted an extremely small number of people who had already installed Windows 10 and applied the November update (Version 1511). When the November update was installed, a few settings preferences may have inadvertently not been retained for advertising ID, Background apps, SmartScreenFilter, and Sync with devices. This issue has been fixed in the update that accompanies KB3120677.
    Not encouraging.....
    2015-11-25T17:36:54+00:00
    Yes indeed, there's no mention either. The tech support advised me to get unit replaced and I will see the outcome once I get the new unit :(
