2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-12T21:16:45+00:00
    When I was shopping for something to replace my original Surface Pro, I narrowed it down to two likely replacements: Surface Pro 4 or iPad Pro. I chose the SP4, but with all the problems it's been having, maybe I should have bought the iPad Pro instead! I'm really frustrated at Microsoft right now...
    2016-03-12T23:05:44+00:00
    I am still having the issue after the update from 2/17/16 was applied.  I checked the device manager and there does not seem to be a problem with the installation.  Have any other ideas as to why this keeps happening.  I can revive the machine after holding the power button for 30 seconds but that is very annoying.
    Thank you,
    Sheila Jefferson-Ross
    2016-03-13T07:54:06+00:00
    Hi Josh,
    Thanks for response, however I am reading this because my Surface Pro 4 (i7) is still failing to wake up - I have ensured that the update is fulling installed and there are not issues (fail to load notice in the device manager).
    Can you confirm if this update actually addressed the issue?  or are their multiple issues that you are discovering as you go?  If so, when is the next update that will fix the issue.  I use the Surface for work and holding down the power button for 30sec in front of customers is embracing for both of us.
    As per below comments.  This Surface pro is a laptop and tablet.... doing a 30sec reboot every time (30-40% of time that it goes to sleep) is just not acceptable.
    Please..!  I am a supporter of Microsoft..... Please fix the problem and stop guessing.
    Cheers
    Gareth
    2016-03-13T08:17:07+00:00
    Thank you..
