2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-12T00:43:17+00:00
    Hi Fahim,
    The easiest way to access it is to right-click on the start button. It should be the 4th item in the list. Once the Event Viewer appears, there are a series of folders on the left-hand side. Expand the one that is named "Windows Logs". In that expanded list, the MTConfig errors should be in the item that says "System". I have a bunch of them myself because I have the same issue. Here are my 2 most common errors:
    1.)
    Event 1, MTConfig
    An attempt to configure the input mode of a multitouch device failed.
    2.)
    Event 10016, DistributedCOM
    The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
    {D63B10C5-BB46-4990-A94F-E40B9D520160}
     and APPID
    {9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
     to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
    2016-03-12T01:11:13+00:00
    I guess I have a defective unit also, funny though how it was fine in February and then mysteriously would not wake from sleep all of a sudden later in February
    Yes, may experience is that it seemed to change with time. Right now, for the better.  It wakes when docked, and fan problem and heat problem are mostly gone. Oddly, if I leave it alone to go to sleep naturally, sometimes I find it hot, other times not. But if I put it to sleep with the power button, it does not get hot.
    2016-03-12T02:09:09+00:00
    After a call with a helpful technical person on the Microsoft Support web chat, I tried a few checks and found a corrupt file, which sfc couldn't fix.  So, I bit the bullet and did a reset on the PC - not happy that I had to re-install all those apps.
    After the reset, and subsequent updates including the infamous 17/2 firmware update, my Surface Pro 4 was back.  It awoke from sleep the first time, but couldn't manage a second time.  So, all that effort has resulted in no improvement, just a waste of an hour or so, plus all those apps to put back.
    Back to hibernation ... and the daily tweet to Microsoft.  I doesn't seem to have any effect on them, but it makes me feel less alone in my plight.
    2016-03-12T03:47:00+00:00
    My device manager does not have the exclamation points. I just got the surface pro 4 a few days ago and all updates are current. Problem persists.
