2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-11T20:37:31+00:00
    The firmware update of 2/17 didn't fix the problem.  Have confirmed that it installed successfully, but computer still won't wake up from sleep mode.
    I suspect it may be time to return my Surface Pro 4 and ask for a refund.
    What I find incredible is that I spent a lot of money on a new PC for Christmas, that is defective, and Microsoft seem to be doing little or nothing about it.
    Perhaps the best description for this device is "junkware".
    If enough Surface Pro owners go back to their Microsoft stores and ask for a refund, perhaps Microsoft may actually devote some resources into fixing the problem.
    2016-03-11T21:26:31+00:00
    Unfortunately the closest thing I can offer to constructive feedback is to try to restore the device to factory defaults, perhaps using the recovery image from here.
    Otherwise it looks like you may have a problematic unit.
    I can confirm that the February update does not fix this problem. I took my first unit back to the local MS store and they confirmed that the update had been applied and they were able to witness the sleep problem. They concluded it was a problematic unit (less than 31 days after delivery)  and exchanged it for a new Pro 4 which they fully updated. That unit performed flawlessly until I installed Microsoft printer drivers for my HP and Brother printers. Then the problem reappeared. Uninstalling the Microsoft signed Brother printer made the sleep problem occur less often. I am sure there is some interaction with drivers here that MS is not testing for.
    Fortunately I can live without sleep, and, as others have reported, hibernation  works reliably.  It is a pity that such an otherwise great design is afflicted with this problem and somewhere MS heads are stuck in the sand.
    2016-03-12T00:01:49+00:00
    Thanks for your response! I've never used Event Viewer so I'm not sure how to look up that information. However, if you have the time to tell me how to find it I'd me more than happy to look it up.
    And has Microsoft said that they're aware of this issue and working on a fix? Or is it just wishful thinking?
    2016-03-12T00:21:43+00:00
    I guess I have a defective unit also, funny though how it was fine in February and then mysteriously would not wake from sleep all of a sudden later in February
