2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-11T11:21:14+00:00
    Unfortunately the closest thing I can offer to constructive feedback is to try to restore the device to factory defaults, perhaps using the recovery image from here.
    Otherwise it looks like you may have a problematic unit.
    2016-03-11T15:50:19+00:00
    Hi All,
    Josh
    Still not fixed. Have 3 Surface Pro 4 and all of them have the updates installed and still don't wake up sometimes.
    2016-03-11T17:22:43+00:00
    I got a brand new Surface Pro 4 about 2 months ago and it's been working fine for the most part. However, about 2 weeks ago after I installed an update I ran into a problem that I'd never had before. Whenever I put the Surface to sleep for more than a few minutes I have to force a restart using the power button in order to turn it back on again. I've looked at threads where people have had similar problems but most people just say to install the latest update, which I have already done.
    This  is a very frustrating problem for a product that's supposed to be a tablet/laptop, and it has caused to lose some important work when this issue first started. For a device that's so expensive and meant to replace my laptop and tablet, this is an unacceptable issue. I'm seriously considering returning the Surface or trying to sell it if this problem can't be resolved.
    If anyone has any advice or solutions to this problem I'd really appreciate it. Thanks in advance!
    2016-03-11T19:30:41+00:00
    There unfortunately is no solution yet for this issue that is plaguing tons of people, especially since the latest firmware update.
    I guess Microsoft is working hard to fix it considering how frequent it is and how vocal customers are in the forums.
    If you know what the Event Viewer is, can you confirm the presence of MTConfig errors in the System section at the time you got the issue?
