2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-10T19:13:09+00:00
    Are you using Windows Hello to log in?
    If yes, can you see the IR emitter when waking up the Surface and facing the black screen?
    If yes to both, you're facing an issue that is plaguing several SP4 users.
    If you know how to find your way in the Event Viewer, have a look in the System section and check for several consecutives MTConfig errors matching the time you faced the issue.
    2016-03-10T19:50:18+00:00
    Yes, I use windows hello.
    I can not see the IR emitter in these situation but the backlight in my keyboard turns on.
    2016-03-11T00:08:51+00:00
    Since that last update, waking my SP4 fro a long sleep has been an adventure - I don't know what it's going to do each time.
    Sometimes I get a blank screen - just black, but with the backlight visible, and sounds of activity (notifications, etc.), but can't get the screen to display anything - power-cycle reboot usually needed.
    Sometimes the touch screen just doesn't work - restart required.
    Sometimes Hello says it's looking for me, but doesn't turn the infrared light on - a few times I've been able to get in just by swiping up the screen from here.
    Sometimes it just doesn't do anything at all and stays comatose, needing a power-cycle reboot.
    Sometimes it works fine.
    I may have forgotten a couple of failure modes...
    When it's playing up, I can sometimes get in using the pen button to open OneNote, sometimes not.
    2016-03-11T05:32:57+00:00
    I got a Surface Pro 4 about 2 months ago and it was working fine until recently. Since about 2 weeks ago, whenever I put my Surface to sleep for more than a couple minutes it requires me to reset it using the power button to turn it back on. I've got the latest updates installed and everything and I've checked forums where people have discussed similar problems, but nothing has worked for me.
    This has been a really frustrating issue, especially since it just came out of nowhere. I've lost some work when this issue first started as well and it's really quite annoying to have to be so careful about putting a device, that's supposed to be part tablet, to sleep.
    If anybody has any advice or a solution to this problem, I'd really appreciate it. Honestly, if this keeps up I might try to return or sell the Surface because a brand new tablet/laptop as expensive as this having an issue like this is ridiculous. Thanks in advance.
