2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-10T02:12:48+00:00
    Press and hold the power button  for 30 seconds, then push it again to turn on
    2016-03-10T04:24:24+00:00
    I bought a Surface Pro 4 in February 2016 to replace my old (but working) Surface Pro. One of the first things I did was install the "fix" to this sleep issue. Sorry to say, it's not fixed on my SP4! I had to use the software restart button, because the two button restart didn't work and it only gave me a screen with some spinning dots. My original Surface Pro worked like a champ and it's a shame that I sold it. Anyway, this is unacceptable, Microsoft! Two out of three products I purchased from MS were failures
    • this SP4 and my Lumia 950XL (which I sent back). At least my Microsoft Band 2 works great!
    • Sent from my non-freezing iPad Air
    2016-03-10T04:54:30+00:00
    Another update 3/8/2016
    It restarted a couple of times (Surface Pro 4).
    Updates for Windows 10 Version 1511
    http://windows.microsoft.com/en-us/windows-10/update-history-windows-10#[March 8, 2016 — KB3140768 (OS Build 10586.164)](http://windows.microsoft.com/en-us/windows-10/update-history-windows-10#)
    This update includes quality improvements and security fixes. No new operating system features are being introduced in this update. Key changes include:
    • Improved support for Bluetooth, wearables, and apps accessing contacts.
    • Improved reliability in app installation and Narrator.
    • Improved performance for hibernation, content entry in apps, and downloading and installing updates.
    • Fixed issue that didn't allow login to an Xbox from a PC running Windows 10.
    • Fixed security issue created when attempting to play corrupted content.
    • Fixed security issue that could allow remote code execution while viewing a PDF in Microsoft Edge.
    • Fixed additional issues with .NET Framework, Internet Explorer 11, and networking.
    • Fixed additional security issues with Microsoft Edge, Internet Explorer 11, USB storage driver, kernel mode drivers, .NET Framework, graphic fonts, OLE, secondary logon, PDF library, and Adobe Flash Player.
    For more info about the security fixes in this update and a complete list of affected files, see KB3140768.
    2016-03-10T05:23:12+00:00
    Hi Josh,
    I've had a SP3 for over half a year and wake-up issues began this week. All updates appear to be installed, so what do you think is the matter? Hard restarting appears to be the only "fix," but that doesn't cut it.
    Are there any known issues with recent updates that may have caused this?
    S
