2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-09T22:27:51+00:00
    I checked my updates and did not see the one refer to. I checked ms update page an no updat is listed for that date.  Can you give us the name of the update that fixes this issue?
    thanks
    There currently is no update that fixes the issue, only updates that make it somewhat better for some while making it much worse for others. The one Josh keeps taunting us with is the latest firmware/driver update which can be found here: https://www.microsoft.com/en-us/download/details.aspx?id=49498
    Your mileage may vary.
    2016-03-09T23:08:40+00:00
    I would like to point out that constantly hibernating or placing the sp4 (or any pc) in sleep accumulates inconsistences and errors in memory which eventually (or not so eventually) will cause all kinds of problems because the OS never gets cleanly reloaded until or unless you do a restart.  I strongly recommend disabling Fast Restart so that your OS gets fully refreshed in memory each time you power on from a previous shutdown.  The difference in boot times is insignificant(maybe 5 second slower) and you will get a faster shutdown and cleaner shutdown as well.  Try it and report back if it helps.
    2016-03-10T01:10:59+00:00
    Josh_F
    The sleep issue is still not fixed on my machine (i7, 64-bit, all updates applied).
    Where would you suggest I post this message?
    I paid $3k for my SP4 with all the bells and whistles.  I loved my previous surface and was hoping for some improvement as well as the flash-factor, but I can't rely on this machine for meetings. It is embarrasing when the i-machines surrounding me work flawlessly.
    I did buy the best warranty available so will likely be returning this machine if the fix does not get made soon.  I paid for the best and expect the best.
    Come on Microsoft, keep my business!
    Tim.
    2016-03-10T01:38:44+00:00
    How am I supposed to install updates when the computer will not turn on?
