2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-09T17:33:48+00:00
    I have a surface pro 4 and i got the update from 2/17 and it still happens.
    2016-03-09T18:04:18+00:00
    I have a Surface Pro 4, I5 with 256gigs and 8 gigs ram. The exact same symptoms. I come back to it, open the keyboard which is lit, but the screen is black. The only way to get back to it is to hold down the power button, reboot, bla,bla.
    Very frustrating and yes I have all the latest updates.
    2016-03-09T18:29:23+00:00
    Yeah, I'm still getting this now and again. Also, on wake-up recently I had 'Hello' say "Looking for you" with the camera off, but when I swiped the screen it took me straight to the desktop. No security at all...
    2016-03-09T20:28:53+00:00
    I checked my updates and did not see the one refer to. I checked ms update page an no updat is listed for that date.  Can you give us the name of the update that fixes this issue?
    thanks
