2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-09T07:57:45+00:00
    I have set it so my Surface will shut down after use. It's quicker to start up and does so reasonably reliably, with no screen problems (nor missing Bluetooth settings and mouse not working which I have reported elsewhere, with little response from MS, no surprises).
    Unfortunately it has MS errors because of some problem when starting up from off sometimes, so this delays things as it works out its message, sends it then restarts.
    However it is very reliable when off—stays on my desk, does not move, is quiet, no battery drain, stays the same color, does not gain weight etc. All good when off.
    2016-03-09T13:10:44+00:00
    Push and hold the power button for 20 seconds then let it go and put it again it will turn on
    Yes -- I tried the same thing, and it has worked every time.  It's annoying, but it has never failed.  It seems to force the machine into a complete shutdown, even when it had hibernated.  When it wakes up, no applications are alive (showing that it was shut down, not hibernating).
    The problem usually occurs after I have been using external monitors.  I try to disconnect them before I hibernate, and that seems to help, but the problem still occurs sometimes even after doing this.
    2016-03-09T13:16:24+00:00
    This is exactly what happens to me, also.  It usually happens when I am using the Surface Dock, but not always -- it happens every few days when I am not using the Dock, as well.
    2016-03-09T16:48:10+00:00
    The 2/17/2016 hardware update didn't fix the issue, I have it installed on 2/19 and I'm still experiencing the issue, my surface pro 4 still won't wake after it went to sleep and I had to hard boot it every time. This is extremely frustrating.
