2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-09T04:09:40+00:00
    not sure that's true, i don't have a dock for example
    2016-03-09T04:57:47+00:00
    Hi All,
    Josh
    Incidentally, I was not having this issue before the 2/17 firmware update. I was having other issues where the battery was draining while the Surface Book was asleep, but I wasn't having a problem with the screen not resuming when I resumed the Surface. After the 2/17 firmware update, I am having this problem. Everything appears to be installed correctly in terms of the updates. I can see in Device Manager that all of the relevant components are functioning. Is there still a problem?
    2016-03-09T05:50:58+00:00
    Hi, i'm still having issues with waking from sleep and rebooting instead.
    The update was successfully installed. Is there anything else i can do?
    2016-03-09T06:41:12+00:00
    Hello All,
    I am one of those who at times experience the death screen.
    I for one will not stop to post and seek a response from Microsoft.
    It will be responsible for Microsoft, if not acknowledging that there is a problem, but post a response of some sort.
    This can take the form of we are still investigating the issue without accepting some legal responsibility.
    Financial recompense, I am not interested. I just one the lovely Surface Pro 4 to become a reliable device.
    Keep Posting...... I think :)
